PoRn Pop Ups!!!!! help... where are they comming from.... SO fast so many!!! ahhhhhh
lotust
Ok im running Windows XP and i got Zonealarm Pro and a hardware router/firewall.
I have ONLY anandtech forums open (not evan surfing) and i get this dam German porn site that keeps asking to install some active Xviewer.
I ran Ad-Aware and deleted some cookies.
what do I do.
I just installed PopUpStopper24.exe its really nice and man it works beautyfull. OMG its wonderfull.
AND I DONT LOOK AT PORN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!often 🙂
no seriously.. im not one of thoes porn acolics. I dont know what was causing this
check your add/remove programs.... sometimes when you install programs (i.e. kazaa and such) they'll install softawre that does that
Get rid of all your cookies.. Unistall some programs that came with kaza or what not. If that dosent work, reformat your hard drive😛
Okay, here's what you do...
-disconnect your connection tool (i.e. cable modem, DSL router, dialup connection, etc)
-<ctrl> <alt> <del> and end any tasks not essential to running windows (OS specific)
-clear cache, cookies
reboot (leave connection media disconnected)
Still getting pop-ups?
nik
loolllll they seed to have stoped by clearing my cookies. But how do I clear the cache?
FFMCobalt
<< loolllll they seed to have stoped by clearing my cookies. But how do I clear the cache?
FFMCobalt
Uh, I'm thinking you can do that by going, in IE, to Tools>Internet Options>Clear History...
Yeah.... if you have "delete files" click that.
if you have "delete history" click that.
if you don't have either one of those, you're not using IE and I cannot support you 😛
nik
ahh ok i did them all 🙂
all seems to be under control
thanks eneryone. I was being invaded by Cable fast porn pop ups.
Yeah, you probably had a cookie on your system that was refreshing itself 🙂
See? You gotta find the upper-class porn sites that don't have crap like that 😉 😛
nik
i seem ONLY to get these when im at anantechs forums?
I cleared all my cookies and temp files. What is this. Ill have to write the adress down. It keeps wanting to install some thing.
what do I do besides reformat?
edit: here is the Url : http://voyour-cams.xww.de
I swear i never been there
<< Uh, I'm thinking you can do that by going, in IE, to Tools>Internet Options>Clear History... >>
No, Clear History is different to my knowledge. It clears the info that you get when you type in a url, and it automatically suggests you websites whose name match what you have typed.
<< quit looking at german porn...turn off install on demand... >>
Actually, the Germans make excellent porn, far better than what is produced here in the US. Production values are higher, the scriptwriting/acting is better (and somewhat realistic), the direction and filming is of much higher quality (better camera angles,etc.). Not only that, but German porn is, well, erotic. This can't be said for films produced in the US.
