- Oct 27, 2005
- 368
- 0
- 0
This is an annoyance that has existed since I built my computer a year ago (see sig). Periodically, while I'm just surfing the web, I hear a little popping sound or a series of little popping sounds in mp3s that I know are pristine. This is something that did not happen with my 5-year-old Dell. Now, the music will seriously stutter and even stop when I'm opening big programs, but this seems expected since both the hard drive and CPU are being taxed pretty heavily. Once things are loaded, the music resumes, but is still prone to popping.
If you don't want to read all this troubleshooting stuff, just skip down to the question at the bottom in bold
I tried a couple things to stress the CPU and hard drive individually. I tried CPU Burn-in, which should stress the CPU to 100%, but not stress the drive (as far as I could tell from clicking) and there was no stutter. I tried playing an uncompressed AVI, which stressed the hard drive, but kept CPU usage below 50%, according to Windows Task Manager and there was some stuttering, presumably until the video had been loaded into RAM. On the other hand, just starting up live tv through my TV tuner, which might briefly max out the CPU (hard to tell, CPU Usage doesn't update very fast), but not the hard drive and it stutters several times.
Here are some other notes about the problem:
-Winamp and Windows Media Player produce the same problem
-Problem exists with CBR and VBR MP3s, high or low bitrates
-Problem exists when running the MP3s from both of my internal drives (SATA and IDE) and a USB external drive
My Dell had a sound card and my new computer build uses onboard sound. Is this a problem that is related to using onboard sound? Or, should this popping problem not exist in either case?
