That is a hard one. It could be your sound card or motherboard. I put my old cheap ISA sound card back in my computer and it does the same thing. However, a good PCI sound card did not.
It's set to do that. Go into sound properties in the control panel to remove the associated sound. I don't remember which one it is specifically, but if you notice there are headings for the various programs there. Good luck and that should do it.
