- Jan 5, 2005
- 444
- 0
- 0
Hello,
I seem to have a problem with precise mouse control in most of the new first person shoorters for instance Call of Duty 2 the most recent example, Starship troopers, Quake 4, Real time strategy D&D Dragonshard.
System is a AMD, WinXp with SP2 Home Built comp, built by me.
CPU: is a AMD A64 2800 Zalman cpu cooler
Mem: 2x184 512meg Corsair Value Select DDR Dims 400mhz
MB: is a chaintech VNF3-250
Sound: Using built-in Sound on MB, I have a Sound Blaster Card, Mlive card should I use this instead of the built-in sound? I thought I heard someone say that SB cards cause freezing, so I pulled it. Seems like now though the processor is having to handle the sound in addition to graphics because in the games the sound option is cpu based sound.
HDD 7200rpm 20 gig.
Video Card Geforce 6800 Leadtek Winfast A400 TDH w/ 128megs vram stock cooling.
Case: ATX Aluminum Lian Li style case 3 fans 1 on the side 1 in the front and back.
Monitor: Dell LCD 25ms response time I think
Most processes are shutdown while I run games except for essential opporations.
Using Directx 9.0c
Latest Nvidia Driver
Game settings are usually high because I have the recommended hardware and sometimes more. However they are not the highest.
Mouse: is a Logitech PS1 optical mouse.
Anyway I just get not precision in games basically the mouse control kinda floats around a bit, makes it real hard to not get killed in games.
Now I have thought that my system might be too weak for the higher settings, so I tried changing graphics for best performance, but alas no luck.
Anyhelp in this would be greatly appreciated and sorry if this is the wrong place for this.
HDD 7200rpm 20 gig.
Using Directx 9.0c
