I recently had to downgrade and change from my 6 mbt Comcast cable to this AT & T / SBC Yahoo DSL that is much cheaper and slower.
Once I get a large lump payment in June I can possibly get it back.
The modem is a Siemens 4100 Speedstream.
From day one I have had nothing but constant dropped connections. After several days of dealing with this, calling tech support, etc, I had them send me a replacement modem.
After a day it started dropping again.
The fix is to push the reset button, log into the modem, click connect, and it fixes itself usually for an hour or more, sometimes it will drop rarely in the next 30 minutes.
It seems to happen the most when I am playing my online EverQuest II.
I can stand around doing not much, but when I am just engaging or in a fight, it will drop.
I can recognize the symptoms quick enough now so it doesn't completely disconnect me from the game, and instead drops me to the character select screen, if I am quick enough to log into the modem page.
Rarely do I notice it has dropped while downloading torrents.
I have a theory that either the modem can't handle the load, or the line quality isn't good and it contributes to the inability to handle the load.
One of the tech support people said that a speed test showed good, but my test at Broadbandreports.com showed a MAX over all the locations tested in the 300s up AND down!
He tried to blame my computer. Yep that's the way to solve the problem. Blame the customer's computer. I even humored them when they said to move it farther from the computer to rule out interference. I have had the cable modem right next to the computer with no problems. You can only move it so far with the length of the cables given anyway.
The replacement modem didn't come with replacement cables though...go figure.
On all those tests it always said I was ~80% worse than the average PacBell.net user.
This is extremely annoying. Just last month using cable I would NEVER go LD (link dead).
Does anyone have any ideas about this?
