Hi all,
I've run into a strange audio problem suddenly after a system restart. The audio quality in Windows 8.1 seems to have dropped considerably out of nowhere. Very little to zero bass, a hissing after any instance of audio stops playing (most noticeable with system sounds), and crackling. I've tried everything I can think of: clean installs of both Windows 7 and Windows 8.1, switching between the onboard Realtek sound and an Asus Xonar DG sound card, removing and reinstalling the newest drivers for both in every possible order, disabling sound enhancements, changing Default Format sample rate and bit depth, etc...nothing seems to be doing the trick.
Here are my current system specs:
Windows 8.1 Pro (though as noted, tried in Windows 7 with same results)
i5-4690K 3.50GHz
8GB ram
GTX 970
I recorded a video showing some hissing after system sounds play. Rapidly changing the volume leads to crackling and popping, hopefully it's audible enough: https://www.youtube.com/watch?v=UMbWjAZA3UY
This is a new build and the sound was perfectly fine (I've been up and running with it for a few days)...until it suddenly wasn't after a restart - so I find it hard to believe it's a hardware issue but anything's possible. Does this problem sound familiar to anyone? Any ideas would be greatly appreciated.
i5-4690K 3.50GHz
8GB ram
GTX 970
