Pondering replacing my Blu-ray player, wondering about audio outputs specifically
mikeymikec
21,619
16,895
I'm looking at two Panasonic models of BR player:
It seems to me that the only difference between the two is that the second one has two HDMI outputs, one for video and the other for audio.
If I were to get an external sound output at some point, wouldn't it make more sense to wire it into the TV so that anything played through the TV can go through the external sound output, rather than limiting it to what gets played by the BR player? The only advantage I can think of for the latter approach is potentially that say an audio CD could be put in the player and the TV doesn't need to be switched on + using power in order to play the CD.
Thoughts?
35,564
With a blu-ray player as the source for a CD going to a receiver, you're probably going to end up having to turn on the TV anyway to see what the player is doing. The front panel displays are usually pretty uninformative.
sdifox
101,200
18,218
Eh? Set source to player. Send play command to player, done. Most receivers support cd-text. The players most definitely do.
