Polycarbonate lenses and bad AR coating, how to fix?
alkemyst
83,769
19
I rarely wear my glasses and my prescription doesn't really change much anymore.
My current pair has flaking coating.
I am all for just buying a new set if nothing can help, but if there is a way to clean this coating off, my glasses will be like new again (and these were very expensive frames).
I looked this up on google, but it's really unclear what works and what people have really tried.
Thanks
crashtestdummy
2,893
You're not likely to have too much luck stripping the coating without ruining the lenses. You should be able to replace just the lenses without changing the frames, though. Should save you a bit of money.
steppinthrax
3,990
Thanks
HAD THE SAME PROBLEM WITH A PREVIOUS SET OF LENSES
I was doing some research online, apparently the coating on the lenses are made from glass. I believe I went to MJ designs or Michaels crafts or JoAnn and got this
http://www.walmart.com/ip/12347708?w...491390&veh=sem
I applied it all over the lenses, within a few seconds the coating was gone...
disappoint
10,132
382
Have you tried nail polish remover aka acetone? If that doesn't do it I don't know anything else that safely will. Then again I'm not a chemist. There is always something stronger like what Walter White and Jesse Pinkman used to eat bodies but I wouldn't touch that stuff with a ten foot pole.
jaedaliu
2,670
I would take it to your local mom and pop optician that does the work in house. Applying a coating should be a $5 procedure that takes 5 - 15 minutes.
With some luck, removing the old coating or just coating over it will be free.
sdifox
100,859
18,078
err, that doesn't make any sense. AR coating is most definitely not glass.
edro
24,326
68
Some AR coatings are fused with the glass in an extremely high temp oven.
At least, in the window world... not sure about eye glasses.
Feb 10, 2000
30,029
67
I expect this will not be feasible without ruining the lenses. Costco will sell you excellent replacement lenses at the lowest price on the market. I imagine they will require that you have a prescription that is less than two years old, however.
sdifox
100,859
18,078
not on polycarbonate eye glass lenses :awe:
dighn
22,820
4
armor etch. look it up. i have used this and it worked perfectly. my glasses turned from a blotchy mess into pristine condition again.
goes without saying but only use it on polycarbonate, not glass!
steppinthrax
3,990
ding ding ding ding ding ding......
steppinthrax
3,990
After having glasses with AR coating on them, I never got glasses that way again. The AR coating seems to get scratched very easily. The only issue without AR coating helps when someone is taking your photo with a flash. Non-coated lenses catch a lot of light....
steppinthrax
3,990
Glass etching solution used to be made from HF(-) (Hydrofluoric acid), and it was pretty dangerous stuff.
