POLL: What's your regular body temp?
Jerboy
Banned
Oct 27, 2001
5,190
Take your temp and respond your resting body temp in the poll. Supposedly average person should be 37.0°C, but I operate slightly cooler at 36.2°C. Measurements must be taken orally. Readings are different for other measurement method(axillary, rectal, infrared-in-ear) and they'll skew the results.
rgwalt
7,393
I was running at 37C, but after installing my Peltier's and a water cooler with AS II, my temps have dropped to 13C.
Ryan
Smacksmackums
Banned
May 21, 2001
591
I don't know exactly what I am, and I don't have a thermometer here. I would like to know what it means if you are low and/or high as your normal temp. Does that mean anything different? I do know that I am lower than the 98.6 degree mark, but not exactly sure.
SWScorch
9,520
the last time I went to the doctors, they took my temperature 6 seperate times with 2 different thermometers. Both read 92.7. :Q
I am usually 98.2 or so though.
freeway
384
I am almost always 96.8. I have had it taken at the docs and at home and it is always 96.8.
Joyride
1,782
<< Measurements must be taken orally.
You sir are no fun!
I am sure you can do it the more invasive way and compare the 2
Amused
57,046
18,364
I hover in the mid 97s most of the time. I have a hell of a time explaining to doctors that if I read at 98.6 I'm running a fever.
Cyberian
9,999
You sir are no fun!
IIRC, axillary should be 1*F lower than oral and rectal should be 1*F higher.
