POLL: what are your P4 temps under load ??
Soulkeeper
6,735
155
just wondering
this question would obviousely negate the importance of different programs/bios readings on various motherboards/chipsets
so just post what your reading is and we'll assume that the off ones will balance each other out
this includes any kind of cooling/voltage config
wicktron
2,573
2.4C M0 @ 3.3GHz 1.525v. Zalman CNPS7000A-AlCu. 43c full load.
2 instances of Prime95, affinity set for each CPU.
digits
512
P4 2.8@3.5 on Asus board 26 idle, 36 load
same chip at the same speed with the same water cooling setup on a abit board 42 idle , 50 load
You figure it out
Kenny1234
317
Originally posted by: wicktron
2.4C M0 @ 3.3GHz 1.525v. Zalman CNPS7000A-AlCu. 3c full load.
how do you get 3c full load?
SuctionCat
21
Voted: 60-70C
2.6@2.8, 216FSB. Stock cooling, Abit mobo, no thermal paste, Australian summer, all of which don't help the temperature that much.
I also run at ~3.15, 5:4. Either way, the temperatures are well above 60. I'm buying a new HSF(Zalman 7000) later this week, along with another 120mm fan or two.
Nebor
29,582
12
Voted 60-70C. Using 5 80mm fans, a Zalman 7000 Cu, an Arctic Cooling VGA silencer on my vid card, passive northbridge, Zalman 400w PS. Running at stock speed w/ P4C 3ghz.
For the record, I don't think my temps are accurate, but I call 'em as a see 'em.
