I`m using Geforce2 MX on a MSI K7T PRO board,Have not had the chance to play all my games since only installed the card today,(120+ games last count)but the ones I have tried work great(Might& magic8,Xcom-ufo enemy unknown,Tachyon the fringe,Star trek-Elite forces(demo),just make sure you install the Via 4 in 1 drivers & use latest drivers for soundcard,plus there have been problems reported with Detonator3 drivers which is being fixed on next update(6.20).
I`m using 5.22 drivers which work great,don`t be afraid to tweak the Bios this can definetly improve stability if you are having problems also don`t buy(if you can help it)cheap ram,use good PSU(AMD appproved if you go Duron,T-bird route with a good fan)you should then be okay.Some people recommend clean install I was lucky, I just got away with reinstalling Win98 os1 over the top(like upgrade).
