Poll: sound recorder help
humax5400
i want to record my voice so i can put in on a cd but windows sound recorder will only let me record for (1 min) and then it cut off. is there anyway you can make it record longer ? or is there any software that will let you record direct to the cd ...
Barefoot
1,024
There isn't any way, that I know of, to record directly to the CD, but if you want the absolute handiest sound-creating and editing program that I've ever seen, go here and download GoldWave. If you also download all of the plug-ins off of that site, you will be able to do just about anything your heart desires with a sound byte :) And of course, it will record longer than a minute. It'll record 3 hours for you, depending on your system memory :)
