Poll: should I upgrade from 24" to 30" LCD monitor?
FreshPrince
8,361
Dell is coming out with a 30" LCD 3007WFP
I have the 24" LCD 2404FPW now, and as you can see, it's sitting on top of an ALLSOP monitor stand.
Width wise, it fits perfectly with the stand. If I upgrade to the 30", I fear it won't look as plush.
Should I upgrade?
edit: all you need to know about the monitor here
dionx
3,500
if you upgrade to 30", you most likely need to upgrade you video card unless it supports Dual-link DVI.
tfinch2
22,114
How about you upgrade, and I'll pay for shipping to take that 24" off your hands. :)
Bozono
Banned
Aug 17, 2005
2,883
No. You should buy a $2000 car and repeatedly run it into a Ditch on a lowly Country Road. If you walk out alive, then claim the car stolen and buy 2 30" displays. :eek:
FreshPrince
8,361
can you give some examples of vid cards that support Dual-link DVI?
currently I have an ATI 9600XT and it supports my 2405 just fine.
it also plays UT2K4 at native res just fine...woot! :p
FreshPrince
8,361
Originally posted by: Mo0o
if you have the money to spare then do it.
I don't want to buy it just because it's bigger..
looking at the specs, it would seem, the 2405 is a better value.
However, sheer size, the 30" is a beast! :shocked:
Mo0o
24,227
so basically if you buy it will be because it's bigger
dartworth
15,200
10
just wait till the 30" comes out and read a few reviews...
then wait for a hot deal:)
FreshPrince
8,361
and if it offers more value like connections, which it does not :(
FreshPrince
8,361
don't worry, I command corporate buying power, which means I don't usually need to wait for the hot deals ;)
dionx
3,500
cards that have NVIDIA Quadro FX 4500 GPU and have a dual-link DVI port.
a single DVI has enough bandwidth to provide resolution to your 24" Dell, but a single DVI does not have enough bandwidth for the 30" resolution of 2560x1600. thats why dual-link DVI is necessary.
FreshPrince
8,361
Originally posted by: Anubis
what does it cost?
seeing as their 32" LCD TV costs $1,799 retail, I would guess the 30" LCD monitor to be a little cheaper. I would guess $1,499 starting price, and soon you could probably have it for around $1,100 with discounts and coupons :)
FreshPrince
8,361
man, those cards are expensive...seems this would not be a smart purchase after all :(
dionx
3,500
what does it cost?
i think it would cost higher than the TV as the LCD TV has a lower resolution than the computer LCD
shortylickens
80,287
17,081
If a 24 incher isnt good enough, then a 30 incher wont please you.
(DAMN! THAT did NOT come out right.)
