- Aug 9, 2005
- 168
- 0
- 0
I was just curious on how dangerous RAID 0 really is. I don't mean any costly RAID 0+1 or anything I mean just plain old RAID 0.
Originally posted by: Kensai
The problem with RAID 0 is that when one drive fails, your array is dead.
I myself prefer RAID 50 or RAID 5.
Originally posted by: Coherence
Consider RAID 5 before RAID 0+1. It only requires 3 drives and gives you 2/3rds of the total capacity of the drives, while 0+1 requires 4 drives and only gives half the capacity.
So, with RAID 5, you get striping-speed reads and fault tolerance with fewer drives.
thing with raid 5 is that just because 3 drives will work fine, it won't be fault tolerable with 3 drives, needs 4 drives so at least one drive can die.
No.
What you're talking about is three drives with a hot spare, making four drives.
Three drives in RAID-5 is also fault-tolerant, as the array will keep running (albeit at a reduced speed) if one drive dies.
Are you sure about this? I thought I read some where that raid5 requires 4 drives to be fault tolerant and 3 drives works ok but if one drive fails the array is gone.
Nope, technically you can even do RAID-5 using two drives, although at that point, it's essentially RAID-1. The basic idea with RAID-5 is that however many drives you have, one drive stores enough redundancy data that if any drive in the system fails, its contents can be reconstructed using the remaining drives (if two drives fail however, it's dead). Technically I think the redundancy data is actually distributed across all the drives in the array, but it is logically equivalent to using a single drive to store all the redundancy data in all aspects except performance (distributing it improves performance because if it was all kept on one physical drive, that drive your bottleneck the array).
Originally posted by: ElTorrente
Just remember that RAID isn't necessarily for keeping your data safe - it's for keeping you online and up and running in case something happens to a disk. Raid0 is, obviously, for speed only.
But when everyone seems to say that the speed increase is marginal... one wonders why people use the dang thing.
I mean, yes, entertaining to learn, amusing I suppose if you don't do anything with the PC--or if you're the dedicated type who frequently backs things up. Just seems like it's too risky if you're doing something even marginally important... like say, 5th grade homework.![]()
Ah, well, the server crowd is different. Something tells me that most people running those actually have made a backup of their important data. My comment was generally geared towards those who happen to think that RAID-0 will help their gaming, and only later realize that a.) it didn't, and b.) the important files on their computer are now gone.
...If you are willing to spend the money on good equipment. My setup is absolutely nuts doing anything that involves disk access. Loading levels in BF2, for instance, is hilarious. I am in game sooooo long all by myself every single time a map changes, that I can cap a flag before the second guy makes it in-game - then slooooowly the other 63 people start filtering in.
