What happens when someone has 4 GB of ram then ? Are you forced to go Vista or should you use xp 32 bit still ?
If you want to use all 4gb, then yes you need Vista.
Is it worth being able to use all 4GB ? Lets say you don't care? How many GB or MB of ram will you loose ?
You can use around 3.2GB of it. For XP you don't really need that much ram anyway. It's not like it can make use of it. Vista has Superfetch which will make use of all of your ram. It's why ignorant anti-vista trolls say Vista is a memory hog. It isn't, it just actually uses your ram instead of letting it sit there doing nothing.
The only problems with Vista are driver problems, and it's really not the fault of the OS. It's been a year now and Hauppauge has yet to release a working 64bit HVR-1600 driver. It's the only think keeping me on 32bit Vista. Needless to say I will never buy another Hauppauge product again.
Newsflash. On a 32-bit Vista install, you still won't be seeing 4GB of ram. Expect a maximum of 3.5GB.
