What is the cat5 cable length limitation for 100Mb switches (NOT hubs)?
I am aware that the limit for fast ethernet is 100 meters, or about 300 feet. So, here's my problem...
I have a 250 foot cat5 rj45 Belkin cable that will work properly when connected to a 10Mb hub from my computer. But, when I connect the same cable to my switches (Linksys 5 port and Dlink DSS-24 port), the link light goes off and I have no connection.
Is there a difference in signal attenuation between switches and hubs? I do not have any 100Mb hubs to test on though.
So far my guess is that the 10Mb hub I used acts like a repeater. However, switches on the other hand don't seem to be able act like a repeater. My reasoning is based on another similar problem.
I have 2 switches that are about 200 feet apart in my warehouse. When I connect them directly, the link lights don't come on. But only when I put 2 leftover 10Mb hubs in between them, then they link up! although not at 100mbs 🙁 like so
100MbSwitch<--->10MbHub<--->10MbHub<--->100MbSwitch
anyone got any insight? You guys have come through for me on some esoteric stuff before, so I hope you guys can do it again! Thanks! 🙂
