Which do you prefer and why? I prefer soft, so when i shower with hard water, it feels sticky sorta, but other people say they'll never shower using soft, since it's "slimey"....thoughts?
<< How do you find out if your water is hard or soft? >>
poke it really hard, if it hurts, it;s probably hard, if not and it feels like you're pushing a pillow in, you've got soft water!
um, not sure how to tell, i've always used soft at home, alot of places use hard though, and generally it's easiest to get a good sudsy lather with soap in soft water, if you feel like it dries up really fast, then it's hard
Q: Why does it take so long to rinse the soap off my hands?
A: The terms "soft water" and "hard water" are important here. Water is said to be soft if it has a low concentration of calcium and magnesium ions in it, and hard water has a high concentration of calcium and magnesium. If you use soft water, the ions react with the soap you use to produce a residue that feels like it is hard to wash off. If you use hard water, you also will have a harder time working the soap up into a lather. Hard water is prevalent in some parts of the country, and sometimes water-softening chemicals that reduce the amount of calcium and magnesium are added to the water.
Hard, but not rock-hard....not hard enough that you can't lather, but not so soft that you can't ever get the damn soap off of you....hate the slimy feeling :|
