time of day makes a significant impact on temperature.
ICD7 is no better than AS5. NTH1 MIGHT be 0.5-1degree better than AS5, but it might have just been time of day and wall-HVAC-thermometer-drift in this hot summer sun.
NTH1 _does_ seem to perform better with lapped surfaces. I do not think the difference can be chalked up to a room temp.
I need to decide if I want to lap the cooler. It's got a very rough, grainy surface that I think might be holding back NT-H1's performance (ICD7 pictured):
1st off -- lap the freakin' cooler base. You don't need to make it "shiny." I usually start with 240-grit wet-or-dry, with the grit becoming "more refined" with use. Then I use 400-grit. For some TIMs, scratches in the surface may actually improve the performance, but you likely couldn't measure it. Lapping the base on that cooler shouldn't void the warranty on it -- as if it would ever matter with heatpipe-MTBF = 1 million years.
2nd. If you're showing no difference in the ICD and NT-H1 or AS5 performance, the inconsistency of your result with published or first-hand observations is easily explained by your very sharp photo (a thank you follows later.)
I don't care what Noctua says, nor can I remember. But even their directions -- no less those of folks who've tried it and think it's too unwieldy -- erase any doubt that just putting a blob or a line of the paste on the center of the cooler won't spread it in any optimal way. Micronized diamond is an abrasive; it will form its own "locked matrix" even with additional layers of diamond piled on a hypothetical single layer, but that's not so much the problem in your case. You may not have used an appropriate amount of the paste; what I see there seems grossly inadequate for the surface area. Whatever amount is used, and howsoever you take pains to make a thin application on a nice flat surface, you want as much as possible of the IHS copper and heatpipe-base to make contact with diamond particles in between like an Oreo-filling.
A credit-card used as a spreader is adequate. I recommend a rectangular razor-blade of the traditional design, but even the trapezoidal shop-grade razor-blades will suffice. (Just exercise a bit of care. If you're epileptic or have some nervous disease with spasms or shaking of the hands, get someone else to do it while you "direct" the operation.)
About the photo. It either shows "gaps" between the aluminum and copper pipes, or it shows a "shadow" if the copper pipes with aluminum splines form a consistently uneven surface.
This is important to ME -- because I'm contemplating use of IX on the ACX cooler, and other pictures I've seen suggest no gaps or channels between the pipes and splines. IX guides discourage use with direct-touch coolers which have apparent grooves or channels between the base surfaces and the pipes, or even between the pipes themselves if they lay side by side as with the 212 EVO.
So if I've convinced you to do the work and lap the base, I'd like to see a new photo -- equally as clear and sharp. IF it doesn't come out that way or you simply don't want to do it, you can just tell me after you've inspected the lapping result.
You could just as easily spread ICD on the processor cap before dropping it in the socket and latching it. It's important to avoid "tearing" the layer; an oval of it can come loose if you move the razor too quickly to spread it. Personally, I "guesstimate" the position of the processor on the bottom of the HSF base before securing it, and I spread another square of diamond paste on the base surface. It can be a really fine layer on either IHS or HSF-base, but it must be continuous, and you cannot rely on it to spread itself unless you use copious amounts.
