Poll: Does your PC have LED/RGB?
BFG10K
Here's what I have:
  • Keyboard yellow backlight.
  • Mouse blue accents.
  • Magnetic blue LED strip inside case.
  • GPU pink logo.
  • Motherboard breathes orange near NIC port.
My monitor's screen has LED backlighting. That is all, unless you count the infrared light of the laser diode tracking system in my mouse, as an LED, and count mobo power-on LED, case bezel power, HDD, and media reader LEDs, hub power indicator LED, external HDD's power indicator LEDs.
My ram, motherboard, GPU, keyboard and mouse all have RGB. Everything is off except the keyboard and mouse.
The PC is on the floor and has RGB on 4 LL120 case fans, 4 light strips, memory, motherboard and GPU. I set it all to a fixed white color at 30% brightness. The G910 and G13 keyboards have backlit keys, which are much dimmer.
So RGB cables are a thing.
Mobo, ram and fans have rgb. My gpu had it but I switched to a 6700 xt recently and got one without rgb. Don't miss is.
I have a system with only a little on the mobo. I also have a system that has fans, mobo, ram, because the case came with them. It was an impulse purchase when I was in store at Best Buy. I used it as a xmas tree last year. 😛
If the best parts didn't come with RGB, I wouldn't get any RGB. I believe my mobo is purposely bare. Maybe it has one green led dot. The rest is black. Like almost zero bling. When I built the rig in my sig, I was using the best ram off the QVL for my motherboard. I ended up with the RGB ram because I couldn't find the equivalent in G.Skill's Ripjaws. So, I went with the Trident-Z RGB. All I cared was that it had Samsung B-die chips and had really tight timings.
My system is built into a solid black fractal design case, no windows, no bling. It is dark and quiet and sits behind my 41 inch monitor out of sight. There is a single blue LED that I have covered with a small bit of black masking take so it glows softly to let me know it is on.
I almost went that way, but had more fun doing the bling route. Turning everything on the first time was most satisfactory.
I bet it was!
I have no problem with bling, it just didn't fit the esthetic for the room it is going in, which is all dark wood shelves, black pipe, and old books.
Yes, for now just case accents and keyboard leds. But, I didn’t buy either because of the leds / rgb. Not much of an aesthetics guy when it comes to my mule
Corsair RBG keyboard, Corsair RBG logo mouse.
IBuyPower pre-built case has a couple of lights built-in, Coolermaster AIO cooler has white lights on the pump, and I think there's a small light strip inside the case.
Where it sits, only the front case lights are visible.
