- Apr 17, 2003
- 37,622
- 0
- 76
Originally posted by: shady06
dp
Most people dont replace the stock cooler for overclocking reasons although it does help in that area. Most replace it to get a cooler, quieter system. The Silencer is much quieter than the stock HS/F and directly exhausts the GPU heat from your case.Originally posted by: Crazyfool
Stock cooling of course. Most videocard overclocks are next to worthless. Wanna overclock something, look to your cpu.![]()
That's my plan too.Originally posted by: zodder
arctic cooling silencer for me![]()
And where does all the heat (its a lot) coming off the GPU HS go? It stays in your case raising the temp of everything else.Originally posted by: welst10
I ordered an arctic silencer but cancelled it because I don't think it's necessary. I just remove the slot cover for the PCI slot next to the video card. Cool air will directly flow over the video card fan.
The problem with the ATX design is it is one big plenum. The heat from the two major contributors, the CPU and GPU have no direct intake or exhaust path. They just use the air in the case. BTX will fix that. In the mean time, things can be improved a little with the current ATX design.
What I have done with my setup:
CPU:
HS has a 80mm fan with a duct running to lower front of case. This draws in cool outside air directly to the CPU instead of using hot case air. This also makes this one fan double as a CPU and intake fan. The PS intake fan above the CPU and 80mm rear case fan behind it do a farly good job of expelling the hot CPU air coming off the HS
GPU:
Hard to get a dedicated intake path, but using the Silencer cooler directly removes the GPU heat from the system instead of blowing it back into the case.
The CPU/intake fan (Panaflo M1A) and rear case fan (Panaflo L1A) are both RPM controlled based on temp via Speedfan The Antec True330 fans are also variable rpm, temp controlled.
I have a fast, cool and VERY quiet system with this setup. The Arctic Cooling Silencer is a great product.
Sure, a case fan or CPU/Case fan combo like Dell uses will exhaust the hot air out. The heat always gets out eventually unless you have a sealed system with no vents or fans. The downside is, you are pulling that hot GPU heat through your CPU venting system, which makes your CPU run hotter. It is better to get rid of the GPU heat directly.
It is surprising just how HOT the air is that comes out of the back of the Silencer! I'd rather get rid of that hot air directly.
BTW, Dell does a better job than any other OEM with case/cooling design. Their systems are very quiet and well designed.
Is that 9800P an OEM Dell? Someone told me they use a variable speed cooling fan on it. True?
