Question PNY RTX 4090 and Case
Dave3000
I prefer to get a Founder's Edition RTX 4090 but my next choice is a PNY one. I have a Meshify-C case and in the front of the case are 2 Arctic Cooling 140mm fans. Anyone here using a Meshify-C case with a PNY RTX 4090 and 2 140mm intake fans without fitting issues? Am I better off waiting for a Founder's Edition to be in stock?
I had that case and a PNY RTX 4090. The GPU is 332mm and it won't fit unless you remove a front fan or two. Meshify C fits 315mm GPU normally or up to 340mm with no front fan.
Wait for the founders edition or buy a new case.
I plan on upgrading to a Ryzen 7800X3D, new motherboard, and new RAM next month. I might as well wait until then to upgrade to an RTX 4090 in case I can't find a FE RTX 4090 by then. The case I have in mind is the Corsair 4000D (I don't want RGB) if I do end up replacing my case (if I can't find a FE RTX 4090 by then). I can buy a PNY RTX 4090 and a new case today if I wanted to since I have the funds for it but I don't want to go through the hassle of removing the motherboard from my current case and installing it in the new case and then when I upgrade to the Ryzen 7800X3D removing the motherboard from the new case and installing the new motherboard and CPU into the new case, especially since I plan to upgrade to a Ryzen 7800X3D / X670E or B650E system next month.
