PNY Geforce 3 Ti 200 problems
Jackhole
144
I have the aforementioned graphics card. When I tried installing the previous Detonator drivers (45.23 I think, before the new ones were released) and restarted my computer, the computer would get just past the "Starting Windows XP" screen and then reboot on its own. I rolled back the drivers (to the Windows XP version without tweaking options) and it works fine. I'm hesitant to install the new 52.19 or whatever they are drivers for fear it will do the same thing. Anyone ever heard of this?
smittybg
148
doesnt hurt to try , just make sure you got your pc backed up incase you need to reinstall windows
bandana163
4,170
5x.xx drivers are most likely only an advancement for the FX series.
The 45.23 drivers work on my GF3 Ti200 fine, altough I use the Omega version.
Jackhole
144
I installed it yesterday and I got an error saying that Windows suffered a fatal error because of the Geforce3 Ti200 after the reboot into safe mode. I guess it's back to window's drivers.
