PNY DDR PC-2100 - Help!
bad1550
I recently purchased 2 sticks of PNY PC-2100 DDR 256 memory on my new XFX motherboard. My question is one stick says something like 266 a on the label and the other says 266 b?
The system recognizes the 512 memory but lately I've been experiencing the system rebooting after running an app!
Please help!
Sounds like one of the sticks is going bad or else you have your timings set too aggressively. Try running with only one stick at a time with your normal RAM speed/timing settings. If it works ok with both then you should try taking down your timings to the least aggressive possible and then try with both sticks. If its unstable with one stick..well then you know its either that stick of RAM 🙂
