PnP OS on Epox 8KHA+ and CAS2 setting?
Poontos
2,799
Yah, so should I have the PnP OS setting as "Yes" in the BIOS? I am running a tri-boot of Win98SE, Win2KPro, and WinXPPro. And what if I was just running Win2K Pro for example?
What setting is it in the BIOS that I change my Crucial's to CAS2? I didn`t see anything saying CAS2 in there, but it was a quick glance.
And what will going from 2.5 to 2 do for me? Any other changes necessary to run at CAS2?
Thanks.
Oh and does anyone in here NOT have a rock solid 8KHA+ with the FF code displayed?
SaturnX
3,415
Leave PnP OS set to No, I forget why, but leave it set to no.
As for CAS2, when you goto the DRAM options, set
SDRAM Cycle Length - 2
DRAM PreChrg to Act CMD - 2T
DRAM Active to CMD - 2T
AFAIK, those are the settings for CAS2, please correct me if I'm wrong.
This will give you a small performance boost, not sure exactly how much, almost negligable, but yeah.
--Mark
Rahminator
726
I think you're supposed to set PNP OS to NO before you install an operating system, but afterwards you can set it to YES.
Fruitcake77
10
Does setting Plug'n Play OS to : NO allow for better IRQ management? Is it easier to avoid Windows putting all devices on same few IRQ's this way? I've noticed that certain cards just shouldn't share IRQ's, no matter what specs say.
Mem
21,476
13
Got mine set to NO for PnP in bios for XP OS,
IRQ 0 System timer OK
IRQ 3 Communications Port (COM2) OK
IRQ 4 Communications Port (COM1) OK
IRQ 5 Generic 56K HCF Data Fax Modem OK
IRQ 5 VIA Rev 5 or later USB Universal Host Controller OK
IRQ 6 Standard floppy disk controller OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Microsoft ACPI-Compliant System OK
IRQ 10 Creative SB Audigy OK
IRQ 11 NVIDIA GeForce2 Ti OK
IRQ 11 OHCI Compliant IEEE 1394 Host Controller OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
got no problems with these XP default setup IRQ settings on my Epox 8KHA+ board.
