Pm problem
VOdka1000
Hello
I'm new here - I try to pm a seller with a question but I can't.
When I click on pm button a new pop up window appears for a split sec. and disappeared.
Please help.
Regards.
Hi,
Welcome to AnandTech Forums. Two issues:
1. Your problem PM'ing may be that you are using one of the newer internet security programs, such as Norton Internet Security, and your settings are too strong. It may also prevent you from updating your profile. If so, try temporarily turning it off to see if that is the problem. If you are using the firewall in Windows XP, temporarily disable it. If that allows you to use PM's and update your profile, try adjusting the strength of your settings.
2. If you are going to trade on our forums, either by posting on our For Sale/Trade forum or through PM's, please read the rules for our For Sale/Trade forum. You MUST display your profile, including your email address (a separate check box), to participate on this forum. To do this, click the "profile" tab and "Personal Options" at the top of the forums. You may have to take care of the first problem before you will be able do this.
Thank you for understanding. We hope you enjoy yourself on our forums. 🙂
AnandTech Moderator
