Plz recommend a power supply for my config
LIT4
80
Asus A8n, AMD 3800x2 ,2GB Ram with LEDs, (7) Western Digital Hardrives,7 LED fans, Geforce 7600GT,3 hard drive 5.25'' racks Edit: + DVDr/w and DVD rom
Thinking of a quality power supply around 700-800ish watts
Thank you
LIT4
80
Guys, I have a 560watt Sirtec ,that I purchased in Korea. I hear that enermax's are sirtec internals. The online calculator reccommended 575 minimal.
John
Moderator Emeritus<br>Elite Member
4
Which bogus calculator are you using? If it's a legit online one you're not using it correctly.
I bet the eXtreme PSU calc will recommend between 350 - 400w even if you put the cpu and psu util. @ 100%.
