plz help me i cant decide on WHAT MONITOR to buy
kiwi_gurl
19
Hi peeps i need some help from you fellow gamers my pc is being built as of now, and im stuck on what monitor to get to go with my beast, im wanting to get a 4k monitor here are my specs
CPU: Intel Core i7 5930K 3.5GHz Six Core Socket 2011 15MB Cache ----Intel Hyper-Threading technology which can thread Six core(x6) to 12 processing threads
Motherboard: Asrock X99 Extreme Series ntel X99 Chipset,
Cooling System: Cooler Master Seidon 240M Extreme Performance Liquid Cooler, 240mm radiator, 2 x 12cm Fan
Ram: 32GB DDR4-2400 Dual Channel Ram (4x8GB
SS 512GB Sata 3 SSD super fast reading and writing
Harddrive: Western Digital/Seagate 3TB 7200RPM SATA 6GB/S
Graphic: 1 x nVidia Geforce GTX Titan X 12GB GDDR5 running in SLI mode
Network: Broadband Ready with Ethernet port Wireless: WIFI 300MBPS
Blue LED Light Strip
Audio: High Definition Audio
Case: NZXT H440 Midtower Gaming Case (Choose from white or black) ---- Clean Inside and Out ---- Effortless Cable Management ---- For Included Fans (3 x 120mm at front, 1 x 140mm at rear)
PSU: 1000W Continuous 80 Plus Gold Efficient Power Supply, Full Modular for better cable managing and air flow
USBS: 6 x USB2.0s , 6 x USB3.0s
Operating System: Windows 8.1 64bit installed with disc and coa
would really appreciate your views i was thinking about getting the
Asus ROG SWIFT PG278Q 27"
but not sure now as theres alot of mixed views
does anyone have one of these monitors?? if so what are your pros and cons
what other monitors are similar to this cheers ;)
FeuerFrei
9,144
929
fralexandr
2,289
229
www.flickr.com
kiwi_gurl
19
cheers peeps for your replies might wait for the new ASUS one to come out and will check out the ACER one
