Plz help a newbie oc'er...
pubLicEnemy
22
well, ý wanna oc my winfast geforce2 ti200. But HOW?
ý have a software "speedrunner " with the card which u can change the speed of core or memory or something like that. all ý have to do is sliding the bars ahead?
will ý need extra cooling? ý dont wanna turn the chip hell but i want a reasonable increase. what should i do?
from 250/400 to 2??/4??
well, ý dont look for a definite number but what do you think i should change the frequincies for oc'ing without opening the case. sorry for my english
Theslowone
1,779
slowly turn the speeds up, and test it. You should be able to get 275/450, but it all depends. And extra cooling may help but you shouldn't need it. You will know when you have passed the limits of your card, by you seeing either artifacts, choppiness, or your computer freezing, or the program dumping out.
Alex
6,995
i recommend powerstrip but nvmax and other lil apps are nice for tweaking and ocing...
