plz help. 3 case fans, only 2 3-pin connectors on mobo
forbin
silverstone lc-10b
gigabyte k8nf-9
this board only has 2 3-pin power connectors on it, how can i get power to the third case fan? theres an empty 2-pin connector on the other side of the board. can i run the two fans in parrallel by splicing... there has to be a simpler solution. thanks guys
cool thx. u think theyd carry that at compusa... i guess i could check their website. sure they'll be closed tomorrow. i always get burnt by holidays
They should carry it. If they don't, they should heh.
EDIT: Just looked on their website for a few minutes with no luck. Often stores will have different items than their websites though.
yea i just took a look too and didnt see anything. i may just hack something inside the case, i do have a skinny wire coming out of my ps and if the voltages match. (seasonic tornado 400)
what kind of projector do u have, widescreen right? nice setup u got
Yeah, with just 12v you can hack it yourself.
The projector is an Infocus 4805. 🙂
