Bateluer
It doesn't happen every time, though it does happen when the Forerunner battery is running low. I thought this was an issue of either the USB port or my PSU not being able to push enough juice. My system is fairly full. However, I dug out my old powered USB 2.0 hub, and plugged the Forerunner in through that. Even with the hub receiving power from the wall socket, the Forerunner still makes my system reboot.
Right now, I've got the powered hub connected to the USB ports on the side of my Dell 2005FPW, which runs to the USB ports on the motherboard.
AM2 X2 4200
MSI K9N SLI Platinum
Fortran 450w PSU
AMD Radeon X1900XT
WinXP
Anyone know what is causing this? I was inclined to believe power was the culprit, but the Forerunner should be receiving any power it needs from the powered hub.
AM2 X2 4200
Fortran 450w PSU
AMD Radeon X1900XT
WinXP
