is it durable for people with kids?
Here you go:
https://www.homereserve.com
1. Waterproof option available
2. 10-year frame warranty
3. Separates into 3 pieces: frame, padding, cover (easy to replace parts)
4. Ships from online ordering
5. Buy per piece, or as a set
6. Lots of colors available
7. Can change colors easy
8. Can re-arrange easy
9. Built-in storage
My previous couch was from a different brand (same modular concept), although this brand is much better quality. It's pretty cool because you can rearrange the room at will, so if you're having a party you can move everything against the wall, or if you want to build a fort with your kids, or setup for movie night, or whatever, you can adjust it as needed. If you want to redecorate the room, you can just replace the covers instead of buying entirely new furniture. If the kids destroy any part or piece of a part of the couch, it's replaceable. Plus it's available online, so just order & ship, you don't have to go anywhere or worry about matching parts becoming unavailable.
