gqtuazon
Hi. My name is Glenn. As you can see, I am new here and I am seeking for your advice or suggestions. I am a photographer and do a lot of both photo and video editing. I would like to ask if you can recommend a video card that can improve and speed up my computer a little bit. My current Windows 7 64-bit experience for desktop Aero is only at 5.1 which went up after installing the latest driver from MSI. Gaming graphics is at 6.2.
Here are my desktop computer specs:
Mid tower case AMD Phenom II X4 945 processor 3.00 Ghz
ASUS M4A785TD-M EVO mother board
8 Gb DDR3 RAM
Logisys 600W ATX PS SLI & X-fire ready
1 TB 7,200 RPM HD
Win 7 64 Bit Home Premium with Service pack 1
GPU: ATI Radeon 5450
The reason why I chose this card before was that I had a bad experience with my previous GPU where in the cooling fan fried or gave up. This GPU operates using a heat sink only. My budget for now is around $150 or $180 tops. I am not sure if I provided enough information in order to get a better video card recommendation that will work with my current components. Reading the reviews from online users aren’t really as detailed and old in most cases which is why I am happy that I found a forum that is dedicated to computers. Thank you for your help in advance. Regards, Glenn
8 Gb DDR3 RAM
1 TB 7,200 RPM HD
