PLS Help Creative T7900 speakers ?
Parjolata
Wired remote control on my T7900 speaker system is damage ,for a 2 month only (( ,and now he didn't work.I serch for spare part remote control unsuccessful in the PC firms.If it is necessary i buy a new but where ? or to find a use for something one Decoder DDTS-100.If i buy DDTS-100 is that decides the issue of ?????
Wow... ok... uhhhh...
So your wired remote broke on your T7900s? If so, you'll need to get the exact same part for replacement I think.
I found this one on creative's site, but it doesn't include the T7900s on the list of compatable speakers.
I think you should e-mail creative support and ask them if that one is compatable, and if it isn't, then see if they have something available that is compatable with yours.
I'm almost postive that the T7900 is exactly the same as the T7700, except for the fact that the center channel is horizontal. Creative probably got tired of all the "which one's the center channel?" questions.
To be sure, go to Creative's website at www.creative.com and send an e-mail to Tech Support asking whether or not the remote YOyoYOhowsDAjello linked to will work with your set. I assume that English is not your native language, so be sure to select your region by clicking in the upper-right corner of the Creative website.
