my specs:
amd athlon 64 3200+ 939 oem chip (new)
msi neo2 platinum edition (new)
cooling is thermalright xp-90 with 92 mm panaflo fan
artic silver applied to cpu core
2x512 pdp (patriot) pc3200 with xbl technology (new)
200gb ide seagate hd (new)
evga geforce4 ti4200 128mb (used from my old working comp)
enermax 420 watt noisetaker (new)
right now i hooked up the video card, ram, cpu, and hd. hd is on master on ide1. and vid card is in agp slot.
i applied artic silver 5 just like it said on the instructions here http://www.arcticsilver.com/ar...ilver_instructions.htm got the thermalright xp-90 on just fine. i know my power supply is fine. it is powering up the fans on the cpu and northbridge and powered up my old computer as well. i tried booting with 1 stick of ram first in the first dimm slot. no go. i then proceeded to swap dimms and try 2 dimms. still no go. (computer powers up but nothing is displayed on the monitor. well... fans run at least.)
what steps should i take from here? try another video card? maybe bad cpu or motherboard? try other ram? argh so frustrating!!! any help would be appreciated? live in illinois? i'll drive to your house!
thanks in advance,
extremely sad
thanks in advance,
extremely sad
