PLS ADVICE: Error Message While Installing XP Pro SP2
Icuba
14
The instruction at "0x7c925e88" referenced memory at "0x4000000c". The memory could not be "read" : This happens while installing XP at about 20min remaining when clicking OK it completes the installation but then I can?t load drivers or software, then I get the pop up window that says " a error occurred and the application was closed " .... I was informed that it sounds like my memory that is faulty PLEASE ADVICE ANY1
mechBgon
Oct 31, 1999
30,699
Try Memtest86 to test your memory. It will take a while, so make sure you have enough snacks :D
If the memory is having errors, please post your hardware details. If you want to be thorough, you can hit Quote and edit this example with your own info... but I won't blame you if you don't. ;) At least give brand & model of all the major parts.
  • CORE HARDWARE
    • Power supply Antec TruePower 430
    • Motherboard Asus K8N-E Deluxe
      • Revision 1.03
      • BIOS 1005
    • CPU Athlon64 3000+
      • Core 130nm Clawhammer
    • Memory (2) 512MB Corsair XMS 3200C2 modules
      • Voltage Manually set to 2.7 volts
      • Timings AUTO, results in 2-3-2-6 @ 200MHz
  • CARDS
    • Primary video card ATI Radeon 9800Pro AGP 8x
    • PCI slot #1 (top) empty
    • PCI slot #2 empty
    • PCI slot #3 LeadTek Winfast TV/FM tuner card
    • PCI slot #4 Creative Audigy 2 ZS
    • PCI slot #5 LSI Logic Ultra160 SCSI
    • PCI slot #6 (board only has five PCI slots)
  • DRIVES
    • Boot drive 160GB Seagate 7200.7
      • Interface Serial ATA
      • Controller hosting this drive nForce3 SATA controller
      • Jumper setting not applicable (SATA)
    • Additional hard drive 40GB Seagate 7200.7
      • Interface Parallel ATA
      • Controller hosting this drive nForce3 standard ATA controller, primary channel
      • Jumper setting Master
    • Additional hard drive 18GB Seagate Cheetah 15k.3
      • Interface SCSI
      • Controller hosting this drive LSI Logic U160 card
      • Jumper setting SCSI ID 01
    • Optical drive #1 NEC 3500A DVD burner
      • Controller hosting this drive nForce3 standard ATA controller, secondary channel
    • Optical drive #2 Lite-On combo DVD-ROM/CD-RW
      • Jumper setting Slave
  • OS AND SECURITY
    • Operating System WindowsXP Professional
    • Service Pack SP2
    • Internet connection Cable
    • Hardware firewall Netgear RP614 router
    • Software firewall WindowsXP firewall
    • Antivirus Norton Antivirus 2004
Icuba
14
Thanx again man i am at work now so will try this later ... But u feel its faulty memory ???
Icuba
14
What prog`s can i use to test my MoBo and graphics card and everything ???
mechBgon
Oct 31, 1999
30,699
My Magic 8-Ball says "maybe" :Q Sometimes posting your list of hardware also gives people ideas on what else to suggest. For example, if your 500W PSU is a low-quality brand, and you have six or seven drives plus a 6800GS on it, then people might suggest trying a high-quality PSU as a fact-finding step.
bendixG15
3,483
You should run the updated version which is memtest86+
found.. http://www.memtest.org/
Got to load this to a CD or Floppy and run for a few hours, exactly how long is debatable. I think that 6 passes (several hours ? ) is enough for a first diagnostic effort.
Icuba
14
I am not sure what make the PSU is it came with the box ... That description of ur pc is that from that prog or did u actually type it out, then I can post those details if it does ????
mechBgon
Oct 31, 1999
30,699
Open the computer case and look at the label on the PSU, it will say the brand & model.
I used to do so much hardware troubleshooting that I made that sample template for people to edit. I saw most of the necessary information in your other thread where you listed your hardware, so if you can find the brand and model of your RAM (so I can look up the preferred voltage for it), that would be good. :)
(specs from other thread:
Intel E6400
Asus P5B Deluxe
1GIG DDR 800
80GIG SEAGATE SATA - OS
2x 320 SEAGATE SATA - STORAGE
160 & 250 SEAGATE IDE - STORAGE
500 PSU
GAINWARD PCI-x 6800GS GLH BLISS DDR3 512MB 256Bit )
Icuba
14
Thanx u r a great HELP ... I tried checking the make & model but its not on the side i open normally ... Sorry had a dumb moment there i can just remove the other panel .. LOL
