- Oct 17, 1999
- 12,505
- 3
- 81
1. What YOUR PC will be used for. Non gaming. Music production, and home entertainment.
2. What YOUR budget is. This depends on which AMD Ryzen CPU I get. Right now I have my choices are the 3600, 3700, or the 3900.
3. What country USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. I will get an AMD 3000 cpu. and probably an Asrock motherboard
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. Hard drives contain content and case
7. IF YOU plan on overclocking or run the system at default speeds. Default speeds
8. What resolution, not monitor size, will you be using? 1980 x 1280 I am not actually sure...
9. WHEN do you plan to build it? Within the next couple of months
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? Windows 10, Blu Ray playback
At the end of the day it's your money. There's only so much we can do.
Updated System so far:
CPU: AMD Ryzen 3700 or 3800. The 3600 is probably enough but I like the idea of having headroom to future proof.
Motherboard: Asrock X570 Phantom Gaming X
RAM: G.Skill TridentZ RGB Series 16GB Desktop Memory Model F4-3600C17D-16GTZR
GPU: RX 590 8GB
Boot drive 660P 1 TB
Content Hard drives, carry over from my current system
Power supply: EVGA 750 GQ, 80+ GOLD 750W
Case: will use my current case
Monitor: use my current unit.
You help is appreciated
3. What country USA
GPU: RX 590 8GB
