Please review my system build
Atvar
Hi,
My computer recently died on me so its that time again! Please check out my specs I put together, I built this with the possibility of getting another 6800gt in a few months.
AMD Athlon 64 3700+ San Diego 1GHz FSB Socket 939 Processor
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
eVGA 256-P2-N376-AX Geforce 6800GT 256MB GDDR3 PCI Express x16 Video Card
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model
Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive
NEC Black IDE DVD Burner Model ND-3540A
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply
Antec Performance I P160 Silver 1.2mm anodized aluminum ATX Mid Tower Case with Swiveling Front Control Panel features LED Display - Retail
Thanks for any suggestions!
Woah that P180 is sweet, thanks for the suggestion!
One more thing, can you guys suggest a nice heatsink/fan for my cpu?
I've been very satisfied with the Zalman CPU coolers. Another HSF to consider is the Thermalright XP-90. The Zalman is designed for reduced noise. I'm not sure about the Thermalright (I'm sure someone else will chime in about it).
Zalman, thats right I've heard they are good. Thanks guys!
Indeed. The 7700CU is a great one. Many other will recommend the Thermalright XP-120 as well, either of those are great.
