Howdy.
Been a long time since I've built a new machine, so I spent the last two days solid, reading up on relevant new tech and reviews, here and elsewhere, then sussing out decent price vs hassle options. So, at this point I am begging for some of you smart guys to review what I've laid out as my proposed build and tell me where my mistakes are and/or where improvements can be made while remaining on/near my intended price ceiling.
Ok, first things first. My budget is $1500. I can push a little higher, but I don't think I'll need to, based on my own research. My usage is primarily typical graphics and video work, but nothing professional. My gaming desires are also probably pretty typical: I want smooth FPS with high(est) settings on current and semi-current popular games. I don't play anything competitively, and I'm not concerned with setting records, so "excellent" performance is good for me; "insane" can be saved for those with more money and more time to kill Nazis or level grind.
I want to overclock with stability. Here again, I'm not interested in pushing the envelope beyond what's been deemed reasonable, but do want to squeeze out all the blood that's safe/fairly easy to get to.
I'll continue using W2K Pro, as I'm very used to it and it does what I want. However, I'll be dual-booting with XP, as well, from the start. I'll add in Vista later on when I feel I have a need for it. Early note: I plan on 4GB and I do know that a 32-bit OS will only reach about 3.2GB of it. However, the prices are really good right now, and it'll have more purpose later with Vista.
I'm in the USA.
I think that handles the preliminaries.
Now for the components I have tentatively earmarked. The prices are what I've calculated as my exact costs including shipping and taxes where applicable. I did shop around a bit, but most of my results point back to Newegg, which is fine by me. I'm open to lower-prices from alternative sources as long as the outlet is known to be reliable.
GIGABYTE GA-P35C-DS3R mobo ($179.80 - Newegg)
Intel Core 2 Quad Q6600 ($296.61 - Newegg)
Thermalright Ultima-90 air-cooler + Panaflo H1A 92mm Fan (BX) w/ RPM Sensor ($69.30 - Heatsinkfactory)
Corsair 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit ($88.81 - Newegg after $40MIR)
PNY VCG88512GXPB G92 GeForce 8800GT 512MB - ($287.77 - Newegg)
Western Digital Caviar SE16 WD7500AAKS SATA 3.0Gb/s 750GB Hard Drive ($167.78 - Newegg)
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive ($86.59 - Newegg)
Antec Nine Hundred Case sans PSU ($111.91 - Provantage)
ASUS Black 20X DVD+R blah blah blah DVD burner ($47.40 - Newegg whenever they restock)
I already have an Aspire ATX-520W PSU that was purchased a few months back in anticipation of my 'puter upgrade, which has been in use in my current, older rig. However, at that time, I didn't anticipate having the budget to buy a high-end CPU / GPU nor 4GB RAM for the upgraded rig. That's a much more recent option. As such, I'm very interested to know if the 520W is enough to run this rig properly. My notes say it should be enough under full load and with (at least) moderate overclocking, but I could easily be quite wrong.
The total for this, assuming I bought it all today, comes to $1335.17 which is comfortably under budget, leaving me a little room to consider slightly more expensive options, or additional component(s), if any are recommended. I might have a little more breathing room if Newegg consolidates shipping some, but I'm not sure they do that, and it wouldn't come to that much extra, anyway.
I'll be using the onboard audio as it is especially good (from what I've read) in the Gigabyte mobo I've selected. I already have the other toys (22" widescreen monitor, 5.1 speaker system, rat, keyboard, etc. and so forth) ready to be cannibalized from my current setup.
In case anyone wonders why I have two drives plotted out, it's because I prefer separating my boot/OS drive from a storage/work drive. I intend to use the 320GB as the OS drive, btw.
Thanks in advance for your evaluation/suggestions/etc. I really do appreciate the time anyone spends reading and commenting on my behalf. I really want to make the right decisions and avoid mistakes, and I know you guys will quickly see any red flags I'm not aware of.
Mansooj
I'm in the USA.
Mansooj
