Hey guys. I've been posting at AMDmb for a while and just joined up here. I'm looking to build my first computer, to upgrade from a old Dell I have now. Here is what I've compiled so far. If anyone has any recomendations on better stuff in the same price range please post!
Case: ANTEC Sonata w/ 380Watt True Power -$99
- I'm prety much decided on this. I was going to buy the SLK3700 with 350w Smart Power, but I've heard great things about true power and it has good front ports. May need an extra fan.
Memory: Kingston ValueRam 1 gig (512x2) DDR Pc-2700 CL2.5 - $100
- I was going to get 512mb of Pc-3200 HyperX, but I found a great deal on 512mb sticks of valueram at office depot so i picked up two. Pc-2700 (333) is probably enough, since it matches the FSB of the CPU.
Motherboard: Abit AF7-S V2-$85
- Seems like a popular mobo. Firewire, RAID/SATA, Soundstorm, and stable from what i hear
CPU: AMD Athlon XP 2600+ "Barton", 333MHz FSB, 512K Cache - $90
-Not many other options, this is probably the most expensive Athlon i can afford. Overclocking is not a priority, so the retail HSF should do.
Harvested: Radeon 128mb 9100, Mouse/Keyboard, Speakers, CD-RW, DVD-ROM, floppy, Planar 17" LCD monitor, 2 harddrives, WinXP (you can use the same copy twice after a few months)
TOTAL: $375, don't want to break $400. What do ya think? Overclocking the CPU and RAM isn't a priority. I would only consider it if i really needed it as i don't want to sacrifice reliabilty. i figure in 4-6 months I'll get a cheap 9800pro. Hopefully it will last me awhile! Right now im on a Dell P3 1.4g 128 SD-ram, so i will definitely see a difference
