Please recommend headset/sound card for positional audio in gaming
Who?Me?
[FONT=Arial, sans-serif]Thanks for reading this!
I like playing action games and shooters (Call of Duty, Battlefield, Mad Max, Borderlands etc.). Until recently, I was using a Logitech G35 Headset (USB-connect, soundcard built-in) in 5.1 configuration, which was ok and rather easy to use, but I was never really happy with. Now one of the earpieces came off, and out it went. Presently I am using a Soundblaster Recon 3D with a Sennheiser stereo headset w/microphone (the model no. of which I have failed to locate), but that combination leaves even more to desire.
Hence, I would be grateful for your recommendations for a replacement, at least for the headphones, or both. Browsing the internet, I have so far not found much up-to-date useful information.
For shooters, the ability to locate sounds is paramount, so obviously I need positional audio of some sort (at least 5.1). I would prefer an open design, so I can hear the phone/doorbell ringing. I wear glasses, so the earpieces should accomodate that. I would prefer a headset w/mic, but I'm not adamant about it. Price is not an issue for now. 400 $ for a sound card like the latest & greatest from Creative does sound (sic!) nuts, but I'm willing to spend if really advantageous.
Thanks in advance for your help! :D
[/FONT]
mnewsham
14,539
428
Sound cards generally just use software tricks, I generally prefer a good quality headphone amp/DAC set up.
I am running a Schiit Magni and a Schiit Modi stack paired with AKG K712, gives great positional accuracy for games like Counter strike Global offensive. I use a standalone condenser microphone for talking to people.
DigDog
14,773
3,064
i play quake with no soundcard (think that the original soundblaster is the equivalent of an ALC 883, stuff that has been on mobos since socket 775) and a pair of audio technical AD900X (which i got for half price, around 130 bucks), and i can hear every footstep, every jumppad, every item pickup.
for mic i use a glue-on mic called AntLion, currently considered the best in its category.
bononos
3,942
190
Thanks in advance for your help! :D[/SIZE][/FONT]
Have you read this thread:
http://www.head-fi.org/t/534479/mad...ng-guide-1-8-2016-creative-x7-ps4-setup-added
Win8,10 have changed the driver model so hardware audio acceleration is now supported but it will some before new hardware htrf platforms like AMD's trueaudio is widespread.
guskline
5,338
476
Replaced My Logitech G35s with Kingston HyperX II headset and VERY happy.
