I recently had an electrician put in 8 recessed lights and dimmer switch in my living room. They used Phillips BR30 (13W) indoor soft white flood LED dimmable bulbs, controlled by one Lutron Skylark 150 Watt CFL/LED Dimmer. They make a noticeable buzzing noise, sounds the same no matter what level of brightness the switch is set at.
As a test, I took out all but one LED bulb, and listened to the noise coming from it. I then put that bulb in a socket with a regular on/off switch, and it was much quieter.
Should I try a different LED dimmer switch? Which one would you recommend?
