Please recommend external hard drive backup solution
x26
734
15
Hi;
I need a external hard drive to backup:
2 desktops(200gb and 150gb)
1 laptop (100 gb)
all running win 7 pro 64bit
I'll likely use win 7 backup program instead of proprietary
I need to create system image of the 3 pc's and occasional incremental backup
want usb 3.0
something that works well--WD or Seagate 1 gb or more
I would like to purchase from amazon(prime shipping and NO tax)
Thanks in Advance!!
x26
734
15
Hi;
1 laptop (100 gb)
want usb 3.0
Thanks in Advance!!
Would appreciate one's to avoid as well!!
KingFatty
3,034
What about using a network-connected drive, over a gigabit network it's pretty handy and you don't have to carry it around as you go from computer to computer. I think there are versions that can connect to the network and also connect to USB?
x26
734
15
I have a D-Link DIR-655-1 usb-would that work?
also i'm trying to keep this as simple and cheap as possible for now.
