Please recommend an AM3 heatsink/fan!
GunsMadeAmericaFree
1,400
380
Can you recommend a decent AM3 heatsink/fan?
I had a couple of spare AM2 heatsink/fans laying around. One was the official AMD version, which evidently came with one of my old processors. (probably a BE-2700, or something along those lines)
I just got a Biostar TA880GU3+ motherboard (AM3). I tried installing my Athlon II x2 2.8 GHz cpu in there, and tried both of the heatsinks. Fan wouldn't come on at all, and I threw both of them away.
I'd like to use my Athlon II x2 2.8 GHz for up to 6 months, and then upgrade to a quad core, ~100 Watt Athlon II x4 or Phenom II x4 processor.
Can anyone recommend a decent heatsink/fan that natively is designed for AM3, makes about 25 db of noise or less, and that can be had for about $20 or less? It should work with my eventual ~100 Watt cpu as well. Most of the ones I've seen online, I'm not absolutely sure if they will work with AM3, because they mention older sockets & such. (don't want to have to mess with an adapter) Some say they will only work with 65 Watt processors. I'm still not absolutely sure why the 2 heatsink/fans I had didn't work at all. New fan that came with a Phenom II x2 worked just fine.
P.S. - I doubt I'll do any overclocking - I just want something comparable to what they ship retail boxed processors with
Thanks!
Stuka87
6,240
2,559
I use a Xigmatek Gaia, and it has been great. The install isn't as easy as it could be, as it doesn't use the stock backing plate. So it is a universal design, but works fine with AM3 boards. But its quite, and dropped my 965BE from 63-64C at load with stock heatsink down to 44-45C. The stock fan was also horendously loud.
And as a plus side its half the price of some of the big name heatsinks.
http://www.newegg.com/Product/Produc...tek%20gaia
Gigantopithecus
7,664
You're likely going to have to use an adapter, as most manufacturers include a variety of adapters so consumers using all sorts of CPUs will buy their products. In any event, AM2/AM2+/AM3 all use the same heatsink design. I think 939 does too, but I don't remember for certain.
The Hyper 101 would suit your needs well.
GaiaHunter
3,732
432
I have a Gaia too and working great.
And while it is true you have to remove the stock back plate the installation wont take long.
But it is $30.
VirtualLarry
56,587
10,227
I find it strange that both fans on both heatsinks didn't work. That to me sounds like there is something wrong with the board's CPU_FAN connector.
GunsMadeAmericaFree
1,400
380
I'm intrigued by the Hyper 101. However, I've never done a "vertical" heatsink install. Would something like this be as secure as a regular heatsink if, for example, my two year old slammed my tower over on its side again?
veri745
1,163
4
I wouldn't guarantee that, but there's an awful lot of stuff that could break if your case gets "slammed on its side"; it's definitely not good for the computer...
