- Dec 15, 2006
- 666
- 0
- 76
I would really like to avoid removing the motherboard if possible. I'm running the OEM Intel cooler on my i7 940 OC'd to 3.6GHz right now and the temps are all right (38 idle, 68 load) but it is a tad on the loud side for me. My office is very quiet and it's noticeable louder than the other fans in my case. I'm using AS5 for the compound.
Is there a cooler that would give a decent upgrade in ability which would allow me to install it without taking the motherboard out? I do not have access to the back of the mobo in my case so I would need to remove the board if it's a bolt-down unit.
If the cooling stayed the same and the noise level went down I would be totally happy with that, not trying to be too picky.
Thanks.
Edit: Motherboard is an Asus P6T and the case is a mid-tower Coolermaster, it seems fairly roomy so I don't believe size will be an issue. Am not interested in anything beyond air cooling, even if that were an option. Case cooling is pretty good I think, 80mm intake fan, 120mm exhaust fan plus the 120mm fan in my xClio 750w PSU. It's definitely quiet enough other than the CPU fan. Video card is a 5870 and that seems pretty quiet as well.
Thanks.
