CotswoldCS
I setup a small network for a non-profit making company (hence on a budget) about a year ago using the following:
1 x Windows XP Professional Computer - (Dell P4)- used as a SERVER
3 x Windows 98SE computer (Pentium Class machines).
1 Five port hub.
1 HP Printer connected to the WinXP Dell computer and shared by others
1 x 56K modem on WinXP Dell computer shared by others using ICS (Internet Connection Sharing)
each computer has a defined IP address (192.168.0.x)
I had to do a repair installation on the XP machine (which went very well and solved all known problems) and now have hit a problem.
Here is the problem:
Each computer can see all other computer on the network and can print to the printer no problem. When any Win98 computer tries to access a shared folder on the WinXP computer I get the following error
\\Server\SharedDocs is not accessible
Access is Denied
I can't understand this! It worked fine before I did the repair installation and Win98 users were able to access the 4Gb SharedDocs folder which contains all their documents etc.
My only guess is that some setting somewhere is blocking access to the Server - I'm sure it's some software setting somewhere.
What I have tried:
I have uninstalled ZoneAlarm and reverted to the Windows Firewall. The users are not that computer literate and found this very difficult to use and understand.
I have temporarily disabled the Windows Firewall and Antivirus Software - no joy
I tried reverting back to Simple File Sharing - no better
I have checked all connections and settings - everything seems fine and Win98 computers can view shared folders on other Win98 computers. The WinXP machine can view its own shared folders through "My Network Places"
1 Five port hub.
Access is Denied
What I have tried:
