KarenMarie
- Sep 20, 2003
- 14,372
- 6
- 81
this may sound stupid... but have you tried going into the control panel ... user accounts ... and check that the .net is enabled?
I restored it again, my Windows thing is fixed, but msn still won't connect.
uninstall and resinstall MSN then.
I tried, didn't work. I lost important files too, restoring my system.
Originally posted by: LoKe
I assume you use a router?
Originally posted by: jdobratz
You could try using trillian or some of the other IM programs that can connect to the MSN network without Microsoft's client. Also, you might not want to be so abrasive if you want people to help you.
I'm not being abrasive, only 2 or 3 people actually helped, out of a 2 page thread. Bunch of douches.
I did try trillian, it won't work.
Yea, but you cannot really expect serious tech support help in OT on a saturday night, can you.
anyway... reset your router. i had a problem once where i could not connect to certain site... like samsclub.com and avon.com and AIM would not connect, but trillian would. the tech support guy made me reset my modem and i was fine.
Does this look like "Technical Support" or "Operating Systems" to you?Originally posted by: The Godfather
Originally posted by: Schfifty Five
You suck at computers.
Ok, but i dont see anyone in here helping or giving ideas, so i guess you guys suck as well. Hence, shut the fvck up. Btw: Youre not funny.
