mallebabbe
Hello guys, just a quick question.
is it safe to use 1.4v for a 24/7 overclock?? 4.8ghz
my sytem you can see in, my sig.
these are my settings
bclk 120
mp x40
llc at high
cpu current capability 130%
cpu power phase control extreme
vcc sa llc regular
vccsa current capability 120%
ram at 1600mhz
voltage
vcore 1.395
vtt cpu vcore 1.1250
cpu pll voltage 1.850
rest is set to auto
does it look oke?????
while playing ghost/bf4 the temps stay around 62/65 degrees for the highest core.
when I use maxon 4d and render its about the same.
If I give a bit more vtt cpu vcore can I lower the cpu vcore then??
this is my system
CPU - i7 3820 4.8ghz
MOBO - asus rampage iv formula
VIDEOCARD - sapphire r9 280x toxic
MEMORY - 16gb corsair vengeance 1600mhz
CPU COOLER - corsair h75
PSU - Be-quit darkpower pro 10/1000watt
SSD - Scandisk ultra plus 128gb
Hdd 1- Seagate 1tb
Hdd 2 - Seagate 1tb.
CASE - cooler master haf X
bclk 120
mp x40
llc at high
vcc sa llc regular
ram at 1600mhz
voltage
vcore 1.395
rest is set to auto
this is my system
Hdd 1- Seagate 1tb
