please..I nd SATA2 help !!
martman
157
I need help if anyone has the expertise...I have a Western Digital HD.. model wd-2500ks with sata 2 I didnt get the sata2 drivers installed correctly when installing windows xp. How can I get my hd running in sata2 without re-installing windows xp? Please..someone help!! there has to be a way to do this without me loseing all my files. system specs are below.
Thermaltake Armor VA8000 case
AMD Athlon 64 4000+
Gigabyte K8N-Pro-SLI
OCZ Platinum Dual Channel 4x1024mb(2-3-2-5)
WD 250 gb SATA2 @7200rpm
Ultra X2 modular 550 watt psu
EVGA 256mb Nvidia 7800 GT (470 core- 1.1 ghz mem)
19? Samsung 930B @1280x1024
Sound Blaster Audigy 2ZS
Creative 2.1 80 watt (semi-surround)..lol
HP Lightscribe
shoRunner
2,629
how did you not get them installed correctly? what happened, is xp install now and running fine?
stevty2889
7,036
8
err, there are no special drivers..if your motherboard supports SATA 3G, then it will run at that speed..there are no SATA 2 drivers.
martman
157
@ shorunner...lol.. I really dont know how I screwed it up...lol.. was my first build and I dont think I did the F6 thing correctly when windows prompted at initial install of XP..windows is running perfectly (well..for windows)..lol..
@ stevty2889 ..As you can see in the above specs.. I have the Gigabyte K8N PRO-SLI mobo..and it required I d/l from their site, onto a floppy, some SATA drivers and install them when first installing windows..I am not sure if they were the wrong drivers or I just plain screwed up the install as I was telling shorunner..
I wish i could see the benefits of useing SATA2 as both my HD and mobo support this function.ATM running Everest Home edition ..tells me I amd running my HD in ATA133..and that suxs.If I could "at least" get my Hd running at ATA150 I "might" be satisfied... Thanks guys for the responses
OCedHrt
613
You don't need to provide drivers via F6 when using the SB SATA ports. When drivers aren't provided they will function as IDE ATA devices. They can easily be switched to SATA by going to device manager and updating the drivers for the controllers to the SATA version instead of the default IDE controller (2 of them are real IDE controllers). Do not force the drivers, if they are SATA controllers windows should recognize the SATA driver as being compatible.
stevty2889
7,036
8
Why not run HDtach, and see what speeds your hard drive is running at. The sustained speed isn't going to be much more than 55mb/s(which isn't enough to fully use ATA66, let alone SATA 3G), but your burst rate should be around 150mb/s or higher. Mine gets a 167.8mb/s burst rate, and I didn't install any extra drivers. The press F6 thing for windows, is for older motherboards, that didn't have native SATA controllers, or for raid drivers. It's no longer neccessary for newer motherboards. And if they were the wrong drivers, then windows install wouldn't even see your hard drive, thats why they were needed originaly.
martman
157
Thank you for the help guys.. I d/led HDtach..(free version) and here are results
long test:
Sequential Read Speed(by the graph) from aprox. 62MB/s at 1 GB to 35MB/s @250GB
Burst Speed: 171.2MB/s
Random Access:13.5ms
Average Read: 53.0MB/s
Are these readings about normal for my HD?..Western Digital 250GB 3G?..model WD2500KS?
stevty2889
7,036
8
long test:
Those readings are correct for your drive. I have the exact same one. If your burst speed is higher than 150mb/s(which it is), then it's running at it's rated speed(if it was limited to ATA133, your burst rate couldn't be higher than 133).
martman
157
Thank you guys VERY much..I have been worried that I wasnt getting what I had paid for..again.. thanks !!
