Please Help! XP Pro Installation Problems!
deversol
I have spent several days trying to get XP installed on my system, to no avail.
I have an Asus A7v133 mobo with a 1.3GHz Athlon, and am installing XP on a WD SE 80gb hard drive formatted in NTFS. I also have 768MB of Crucial PC133 CL2 SDRAM, a Leadtek GeForce4 Ti4400, and a Mitsumi CD-ROM.
I booted with the XP cd and setup started. After it copied the temporary files from the CD, I got a message saying "Starting up Windows" and it just hangs there...I had moved the hard drive from master to slave, and from the primary to secondary IDE port and get the same result...I have removed all but one RAM chip, removed the sound card, ethernet card, everything but the video card, hard drive, and CD-ROM. I had also installed an old GeForce2 32MB card instead of the GeForce4. I have also flashed the BIOS to the latest version on the Asus site, ver. 1.009, and get the same result no matter what.
I then put the hard drive in my roommate's computer and was able to get XP completely installed on that hard drive with no problems. I then put that hard drive in my PC, as the master drive, and set up BIOS so that it will boot from there first....I then get an error during boot-up saying something like "Disk read error, press ctrl+alt+delete to reboot"...I can understand that, the HAL is all messed up, but it was installed on my roommate's PC with no problems, meaning that the hard drive is fine.
I had also installed Win2k Pro on that same hard drive in my PC with the same hardware configuration as above, and had no problems. Then, while in Windows 2k, I inserted the Windows XP cd and started installing it. After the files were copied from the CD, XP rebooted my system. During reboot, the black Windows XP screen came up saying it was loading, and it just froze. I tried to reboot several times and it did the same thing each time. Then, I booted from the Windows XP cd and started to install it again. Once the files were copied from the CD, a message at the bottom of the screen said something like "Starting Microsoft Windows" and it just hangs there...
I had also used the official XP boot disks available from Microsoft. After all of the drivers are copied, I get the "Starting Microsoft Windows" message.
Last but not least, I copied all of the files from the i386 directory to my hard drive, booted with a Win98 floppy into DOS, and ran Setup from there....same result as above...
I feel like I have tried everything possible in getting XP installed. Can anyone think of anything else I can try? Ive been at this for days now with no luck...Thankfully I still have Win2k installed on another hard drive so I can still use my computer....
Any ideas? Thanks for any assistance!
Have you tried blowing out the partitiions completely and letting XP prompt you to select what type of partition you want?
Thats strange because I have the same motherboard you do, and I didn't have any problems installing XP. (Boot from CD and let'er rip!)
--LANMAN
"Have you tried blowing out the partitiions completely and letting XP prompt you to select what type of partition you want?"
Yep, Ive done that...theres only one partition on the hard drive and i am able to select it during XP setup...I was hoping it was a motherboard problem, but since you have the same mobo and it works for you, Im really baffled...
What are your BIOS settings? I think I remember seeing a setting in the BIOS when I first installed a OS on the MOBO that cause me some problems.
Specifically in the IDE section.
--LANMAN
A BIOS upgrade might be in order also. I would agree this is a strange problem since Win 2K installs without any problems at all.
Good Luck!
-Spy
"What are your BIOS settings? I think I remember seeing a setting in the BIOS when I first installed a OS on the MOBO that cause me some problems."
Thanks for the responses guys. Im not too sure what my BIOS settings are off-hand (Im at work now), but I do know that I have the Primary Master drive set to Auto in the BIOS setup.
"A BIOS upgrade might be in order also. I would agree this is a strange problem since Win 2K installs without any problems at all."
I have flashed the BIOS with the latest version available from Asus, ver. 1009 ....Im completely baffled why Im having so many problems installing XP 🙁
Originally posted by: deversol<br Im not too sure what my BIOS settings are off-hand (Im at work now)...
I'm at work too, so I will try to post what my BIOS settings are when I get home too. Then we can compare the differences and hopefully get you up and running. 🙂
--LANMAN
Originally posted by: kurt454
Mine won't install with my geforce card in. Had to put an old TNT pci card in. XP installs fine then.
What kind of motherboard do you have? Which Geforce card? Did you experience the same problem I am experiencing?
Ive tried a Leadtek GeForce4 Ti4400 as well as a Creative GeForce2 GTS...I think I may have an old SiS video card...perhaps Ill try that this evening as well...
Had a Matsonic MS8127c mobo(Via 686a chipset). Got a ECS K7S5A now. Gainward Golden Sample Ti 200 vid card. It always hung up at 'Starting Microsoft Windows'. I haven't tried XP since I got the ECS mobo. It is a backup game machine, running 98se at the moment. I believe the XP installer does not like the bios of the Gainward card? Anyway, I would recommend a pci card, if you have one.
XP should would fine with Geforce cards,it does for my GF2 Ti & all my friends have GF3s etc .
deversol, you tried a reformat & use NTFS ?
Thanks guys.
Kurt454, I tried my old SiS PCI video card and it did the same thing 🙁
Mem, Ive tried that several times, as well as formatting in FAT32 and FAT....I just dont get it, I dont think theres any other possible things to try 🙁
Oh, and Lanman, I didnt have time to get my BIOS settings last night...I should be able to post them this evening though.
No problem. I was busy last night anyway designing Visio maps. Talk about dry!!
Catch ya on later tonight maybe!! FGIF !!! 😀
--LANMAN
