Hi all
Hopefully you'll all understand my poor english 😀
I was trying to network together 2 windows XP machines via an outdated Netgear 56k modem router which has a 10Mbit 4 port hub built in. Sorry I didn't get the model number since it's at my friend's place.
I went in setup the two machines, static IP addresses, they were able to see each other in My Network Places, access shares etc. So basically 'working perfectly'.
Then my friend's children comes home and decides to play Counter Strike on their newly networked computers and found it to be really lagging. The host would work just fine but the client would just stutter every 5 seconds of play. I then decided to remove IPX/SPX from their network (I didn't put it there, someone else who tried to fix it before me did), and just leave TCP/IP in there. After this point I did test networking via accessing a share folder right away and it worked just fine very quick / responsive. Counter Strike still lags pretty bad.
Then I started switching cables around and connecting to different ports. I should really have documented it but no I didn't. All of a sudden it takes like 2 minutes to access a share folder. Ping still works fine, typical LAN response time. It's just shares that's really slow, the system would hang for 2 minutes while the hourglass is there.
What do you guys think I should try? Reinstall the TCP/IP stack? Could it be a faulty port? If it is then I shouldn't be able to ping at all.
millions of thanks in advance
ps - Ping is in the network layer isn't it?
